Recovered face displaced
Simple child face previously recovered very good. after reverting all image modifications to original, and reopen same image, the face recovery displaced the face very badly.
Would you mind sharing some screenshots or examples of the problem you are having with these images?
I cannot SELECT the faces on pics that are not real clear. When I force the program to select the only face on the picture, by using CUSTOM select, it gives a little tiny window that does NOT cover the face, and it’s off center. The customer needs the ability to select the Whole face. Also the hair on all heads is cut off and NOT made clear on ALL pictures!
