I have just installed a GeForce RTX 5070Ti GPU yesterday and am experiencing various issues since. In addition to the “Sharpening Standard” issue in Photo AI, there is also an issue with Gigapixel AI producing a pronounced “Snakeskin” effect in Recover mode. In Photo AI, the sharpening filter produces lower quality results in general. I am using Topaz apps as Photoshop plug-ins.
Hello!
Recover is ideal for images with pixel dimensions of 1024 or less. Using images larger than this will produce an in-app warning and can result in undesirable over-texturizing.
Depending on the source image, pre-downscaling the image first to fit within 1024×1024 will provide the best experience for processing locally and giving cleaner results.
Depending on your intentions, use our core models to upscale and enhance most images. After importing an image, I recommend enabling Auto mode to start and build from those settings.
Thanks
