Recover faces preview not correct
The image preview for “recover faces” is rendered incorrectly.
Hi.
Click on the Eyeball next to Recover Faces to temporary disable it
Then reduced the Denoise slightly and enable the Recover Faces Eyeball again
Hopefully this will work if not here’s a link to contact Topaz Support directly
Topazlabs Support
support@topazlabs.com
Hi.
I know this sounds obvious have you checked your Drivers for an update
Even reducing the strength of the denoise to 1 does not remedy the issue.
Thanks for the suggestion.
-Jon
My system has been rock solid with the current driver configuration for quite some time and haven’t seen any issues with any other software.
Thanks,
-Jon
Hi Jon.
Sorry to hear that didn’t work please try contacting Support here’s the link
Topazlabs Support
