Steps to reproduce issue:
- open jpeg
- Recover faces. Finds but then corrupts
- Saves it with the corruption
Topaz Photo AI [3.3.3] on [Windows]
We’ve had a few reports of this being a problem with recent updates, and it is usually associated with the system needing to meet the Minimum System Requirements or associated with the GPU driver. I suspect that your machine is more well-equipped than your father’s computer, judging by the screenshots you sent to us to review.
To investigate this problem better, we’ll need to examine your full system profile information. This will help us understand what might be causing this issue.
I would also like for you to try updating the GPU driver to ensure that you are on the latest updated driver for your card. You can do this by following the steps below:
Open your Device Manager
Go to Display adapters and double-click on your GPU. Then go to the Driver tab and Update the driver.
This only started after I updated to current. My PC is older but everything is in spec except gpu. Nvidia GT710 with 4 gig. Will have to go back to previous version for now.
Brendon
