Recover detail slider settings are not being saved in custom preset
    Recover detail slider setting is not being saved in custom preset. When I select the preset it reverts back to a setting of 20. I had it set to zero when I created the preset. I also tried updating the preset with it set to zero. Using nyx HD.
  2. Your system profile
    DxDiag.txt (94.8 KB)
    logsForSupport.zip (3.3 MB)
    N/A
EDIT: I have found if you save it on 20 it loads as 0 and if you save as 0 it loads as 20. Others I have tried like 1, 19, and 15 all save and load as expected. May just be Nyx.
We are looking into this still and troubleshooting what is causing the slider values to not be saved. Working to get it resolved for the next patch update.
