The bug / behavior you have encountered
I have the default export bit rate set to 12 Mb/s, constant, CODEC is H265, profile Main. Regardless of my export settings, the output file’s bit rate is never 12 Mb/s, and almost always lower than the input file’s bit rate.
This has been going on for a few versions now. I believe it worked at first with the 5.X.X series, but now even if I install an older version this behavior persists. -
Your system profile
DxDiag.txt (103.4 KB) -
Your log files (Help > Logging > Get Logs for Support)
2024-06-04-05-36-24-Main.zip (822.8 KB) -
Any screenshots as necessary
I don’t believe screenshots will clarify anything. I am happy to upload the video from the logs, but this problem happens regardless of the input video, enhancement and interpolation settings.
PS: I’m pretty sure this is a “me” problem. Would like to know how to fix it…
