I am waiting for Spring again. Everything covered in snow right now.
Pretty image and a nice edit …
Your work is great. Can you tell me which filter you used? I want to apply it to my picture.
Welcome to the forum, and thanks for liking the image and for your question. Below is the original image. I then extracted the main flower and put it in a separate layer. Back at the original layer, I applied a simplification and abstraction Look in Topaz Studio 2, and also changed the colors by playing around until I liked what I got. I then went to the second layer and applied the same Look, but to much less extent. Unfortunately I can’t tell you much else as I don’t save the majority of Looks I create in Studio, as I don’t want my images to come out looking as if the same effect has been applied to them.
