Hello . I can use “edit” to use sharpen ai but not like a raw plugin, it creates a tiff. Where can i find the raw plugin and add it with the plug-in manager ? Thank you for your answers
Did you look under the plugin command? If not it should be File->Plug-in Extras->Process with Topaz Photo AI 2
If it isn’t there exit LR and reinstall Topaz Photo AI.
Thanks for sharing!
that’s what i’ve done… but nothing appears.
Please disable antivirus, firewall, VPN, or proxy that may be on your computer. These are known to block the installer from downloading the model files.
