Raw file from Lightroom not displayed correctly
[When I export a file from Lightroom to Topaz using the process, the image appears significantly brighter. This also happens when I send raws via the topaz stand alone.
But when I send the image from Lightroom via imageedit in, the color profile matches my representation in LR.
Unfortunately, I didn’t find any options that have an influence on the color profile.
Do you have any idea how to solve the problem?Please describe your issue here. Try to include logs (Help → Logging) and add screenshots if necessary.]
Steps to reproduce issue:
  1. Step 1
  2. Step 2
  3. Step 3
  1. The original image file.
  2. The processed image.
Dropbox File Request
Hi John, i send you the images. Tell me if you…
