Hi,
First, your software is amazing, especially on raw files. (And why does it seem to work so good on raw vs the same file with same settings in jpeg or tiff?)
Anyway, I’m having a consistent problem. I work on gigapixel size images of nature scenes and I’ve been going back and playing around with how much I can blow up previous work of individual frames. I’m finding that there are blurred patches on pretty much every photo I experiment on, which have been many at this point. No setting changes in Photo AI make it go away. OR, it randomly goes away on its own.
The blurred patches can move to different image areas from one file format to the next, or they can move just in the processing of the same file type.
Or, I can be viewing a file in Photo AI’s viewer, see a blurred patch in the same area several times, and then later I pan back to the same area and it’s gone. It’s completely random and not consistently reproducible. It seems to be a bug to me.
Sometimes the area that is blurred is more sharp in the original file, or at least equally sharp as other areas that have been blown up and retained new detail. It’s very weird.
To redo my gigapixel work will take hundreds of man hours and I don’t want to start the job until this wandering/varying blurry patch issue can be figured out. It’s across the board on all types of my photos and file types as mentioned, so I don’t think it’s on my end.
And, I just noted the other thread about this, but count my voice in on this is a big issue of some sort. The person who showed the image of the blurred bush in the other thread, that is exactly what I’m talking about.
Again though, keep up the great work. Once some of the kinks are ironed out, your software will be a dream come true for my work! Thank you!
Below I’ve added a three file format comparison. All of them have random, nonsensical blur, but as mentioned above the blur shifts around per each file type. All settings were exactly the same for the exports. The top is a tiff and has an actual line of solid blur in the top left area. The 2nd down is a jpeg (No compression setting) which has clearer bushes in the top middle than the 16bit tiff. The bottom is raw with its own issues.
The image is from a 50mp Cannon.
