When I am trying to find out which settings of Topaz AI work best I am creating multiple layers in PS, each one with another Topaz AI call. Would be nice to store configuration somewhere. Maybe Topaz AI could name the layer with “Topaz AI sharpen value, face value” etc?
In the future, we’re developing a multi-view where you can view different settings within Photo AI and not just one set of settings and the original.
I can also see how storing the settings info in the export file name could be helpful if you have multiple versions of the same original image.
I understand but multiview is not enough if this is only inside Topaz AI, I want to have result in PS, then I can apply my other changes on top and see which one was best
Thanks for clarifying. I can see how being able to name different Topaz outputs makes the PS workflow afterward much easier.
