It would be great if SAI would record its settings somewhere in metadata. I don’t know how possible or feasible that is. But, it would be very helpful to be able to return to a processed file to recall settings as a learning experience and to compare results from different builds, etc.
I have a problem using Sharpen AI. All the metadata are lost after processing an image and saving as a new jpeg file. Any idea, how to keep all the metadata intact?
I believe the metadata problem is internal with Sharpen AI (and a few other recent Topaz releases) and will be fixed on a major update in the near future. Nothing you can do about it.
