ProRes422 STD exported at ProRes422 HQ bit rates, but still tagged as ProRes STD
I’m seeing a repeated problem, where exporting in ProRes422 is not using the right bit rate or tags when switching between ProRes422 STD and ProRes422 HQ.
Sometimes, if I try to export as ProRes422 STD, it will actually export at the HQ bit rate, even though the file is tagged in MediaInfo as ProRes422 (not HQ). The files are twice as large as they should be, and MediaInfo reports the bit rate at HQ bit rate levels, but as a ProRes standard file. If I then switch and export the exact same file using HQ, the file size will be identical, and appropriately tagged as HQ. In other words, there is no difference in the output, except that the first file is inappropriately tagged as Standard, when it’s actually HQ.
I’ve seen the same problem in reverse, too - where both an attempted HQ export and a Standard export are both saved at the Standard bit rates, even though one file is tagged as Standard and one is tagged as HQ.
This is a pretty serious issue as it would be very easy for someone not to notice that they’re saving their file at a quality level that is not appropriate for their project. Moreover, it’s not even easy to be aware of this problem unless you actually look at the bit rate. You could save a file as ProRes422 HQ, thinking you’re preserving a lot of quality that is in fact being lost, because the file is actually Standard, even though it’s tagged as HQ.
This may not be a P0 bug, but it’s at least a P1, imo.
Can you pull the logs from a recent attempt of this and send to the support team for review? Going to try and replicate this as well to share with the devs for investigation.
help@topazlabs.com
Yes, will pull the relevant portion of the log and send it to the email you provided. This is a persistent bug for me at this point.
Will send much more data via email, but check out this one line from the log:
Stream #0:0: Video: prores (Standard) (apcn / 0x6E637061), yuv422p10le(bt709, progressive), 1920x1080 [SAR 2943:2944 DAR 327:184], q=2-31, 558012 kb/s, 59.94 fps, 59.94 tbr, 19001 tbn (default)
It’s clearly trying to select “prores (Standard")'“, but at the same time it’s using a bit rate of “558012 kb/s”. This is a ProRes422 HQ bit rate, not Standard.
