Program window won't resize correctly when maximising
Hello, when pressing the maximise icon in the programs top bar it will resize the programs window to the same position regardless of how the windows taskbar (Windows 10) is configured. More specifically the program will be resized correctly only if the windows taskbar is set to be always visible on the bottom. If the taskbar is set to auto hide then maximising the program will leave a gap at the bottom. Or in my case I use the taskbar at the top of my screen and that means if I maximise the program it will cut off the top of the program window (hiding the whole top menu bar) and leave a gap at the bottom, this is what I have shown in the picture.
I have the same issue with Windows 10 and the taskbar at the top
