Program will not export to Lightroom Classic
After applying manual adjustments to Denoise and Sharpen the program hangs on processing. Will not export just hangs up.
  1. Changed denoise settings, compared toggling on and off, then xout eye ball
  2. Changed sharpen value because it was to aggressive and compared to other options natural,standard and refocus. Made selection, unxed the eyeball in denoise and tried to export. Hangs on processing.
  3. Log file included
2024-08-31-11-42-26.tzlog (430.5 KB)
