Processing seems to be stuck, progress bar isn't moving and computer is hot
Had used upscale and denoise on an image, no selections. The processing screen progress bar hasn’t moved, been close to six minutes. The fan kicked in on my laptop about minute 2.
Steps to reproduce issue:
  1. Step 1 open image
  2. Step 2 select all over denoise and upscale, hi def 2
  3. Step 3 send to Photoshop (lastest update, 25.11)
Hi! I figured it out, I was trying to upscale using the PS filter, which I just saw from a different post is not an option in the filter and only in the stand alone.
Why is upscale still included as an option if it isn’t supposed to work? Not being b*(chy, just an observation. :grin: :grin: :grin:
