Problema con raw Nikon H*
Hi, even with the 2.0 release I continue to have problems with the Raw Nikon H* (high efficiency), when I save it creates a very strong cyan cast and I can’t eliminate it
Thanks
Mario
@mmorandi1 Thanks for reaching out. This is a known bug that our developers are currently investigating. If you’re using the Lightroom plugin, In the meantime, you can try using the Photo > Edit in > Topaz Photo AI workflow which will preserve color and process a TIF instead of a RAW. If you’re using Photo AI as a standalone app, you can convert to DNG using Adobe DNG Converter:
