Problem with red batches in most of my processed images
Hi curious as to why so many of my images are getting this after being run through the program? making it really hard to process alot of my photos and then having to go back through them.
@kaleb.jeppson thanks for uploading the picture. Very cute.
The pink artifacts are a known bug with the RAW Remove Noise Normal model. We’re working on fixing it for a future release coming soon.
In the meantime, the best workaround is to either use the Strong model or to increase the slider slightly and that should eliminate the pink artifacts.
If you’re not using a RAW file or Remove Noise Normal, please upload the original so I can run some tests.
