De-noise 6.0.1 has taken to displaying the image I am working on as all black and this remains after trying all presets and sliders. The rest of the screen loooks like the normal de-noise screen elements.
This happen as soon as the image is loaded and it seems as though the image is loaded but then a black layer is laid on top. If I zoom out/in the underlying image shows and is then blacked out again.
Problem happens if I start de-noise from Photoshop or directly. I have also re-installed the product with no improvement. Windows 10 64 bit.
If you are using Windows, from the symptoms you are describing, you may need to update your GPU drivers. Please update from the manufacturers web site as per these instructions:
Thanks for this. My system seems to meet the min spec - Win 10 64bit, 32gb RAM and the Nvidia K620 card seems to have plenty of resource and now has the latest drivers - but the problem seems to remain.
What GPU and what version of the drivers do you have. Also check that PS is using the correct GPU if you have a dual GPU system … you can check by looking at the Help → System Info which will tell you what the Video Card Renderer being used is or Edit-> Preferences → Performance will also tell you what Video Card is being used.
I think you will need to raise a support request but remember that they wont be on board until Central time on Monday in the US. I am not sure about the Quadro versions of NVIDIA cards as they are designed for very specific render tasks like CAD design and professional video rendering and not computational work such as the GeForce cards.
