Problem photo AI
my photo Ai is not opening photo from light room. opens with a drag and drop menu. how can I fix it? I have tried reinstalling but still the same.
I believe you need to use the entry in the plugin menu or the edit in:
Can you confirm that you are following the recommended workflow for Topaz Photo AI? Here is a link that describes that process:
Topaz Labs Support | Topaz Photo AI | The Recommended RAW Workflow in Lightroom Classic
