Problem about preserve text tool
When I apply ”preserve text”, the surrounding image becomes blurred…
The same phenomenon occurs even if i select only the text by painting it neatly in the edit selection.
Has this issue already been reported, discussed, or worked toward remediation ?
preserve text issue01
In future use the correct category where it has been moved to.
Site Feedback is for the forum NOT Photo AI bugs!
where is corrcet category ?
As I said in my post I moved it to the correct category, you posted in Site Feedback.
I notice the same effect. For me the text preserve function is basically unusable because of the strong blurry effect of the text area in comparison to the surrounding much more sharpen areas.
Would you mind sending me more information in order to get a better understanding of the problem you are having with this image? I would like to try and reproduce this image, in order to do so would you please send the following information:
  1. The original image file.
  2. The processed image.
Dropbox File Request
