Preview while exporting(with maximum Processes:1)
I am using Tapaz Video AI with maximum Processes: 1
When there are 2 Exports normally 1 after the other will be done.
But when i like to test a preview i have to wait that those 2 exports are finished or i have to set up the priority of the Preview(s) that they would be calculated next. So at least i have to wait that the last export will be finished until i am able to run any preview.
Better would be an additional setting where i can set the amount of processes for Previews seperately.
If “Processes for Previews” is set to 1 and “Processes for Exports” is 1…so 1 export after the other will be calculated…and also i preview at the same time while exporting.
That would make it possible to do previews while one export after the other will be done…
The preview is independent from the maximum number of
It is hoped that the preview output can be independent of its own maximum number of renderings
In this way, when adding a new video to the sequence of exporting multiple video files, it is very convenient to preview it first
Thanks for watching :smiley:
*google translate
