(Preview) Temp Folder Not Saving!
Topaz Video AI 5.2.1
After processing a Preview for image sequence; the files are not saving to the location where I set & saved in option! They are still outputting to the Default location!
After you change the default Workspaces folder in the preferences setting, you will need to create a new project for the preview folder location to take effect to the new location.
File > New Project
