Hello,
I am finding Redefine to be incredibly versatile in cleaning up and adding details to higher resolution images over 1k. The problem is that the previews are not accurate due to the higher resolutions and so there is a large amount of wasted time in trying to resolve the two outputs.
My workflow has been to export with redefine as a base and then slowly go in and screencap previews off the original (which itself can be difficult if the preview is larger than my screen) and then blend them together in Photoshop. This involves rerolling a preview multiple times in order to land on what I would interpret as a close match to the original. Then, after collecting all the tiles I go into PS and do this slow process of realigning and blending each preview.
This is, as far as I can tell, the best way to generate the best quality images using the software but it is very time consuming in scale. To fix this, I suggest something simple, which is the ability to pin previews to output. A button next to the preview that I can click which guarantees this rendered preview will be in the output. The tiles do not have to be blended, instead they just need a one color solid border around them which can be optional, this way you can reselect the edges with ease in PS, or whatever, afterward and mass blend all the tiles in one go.
This would make it much easier to use IMHO, especially for doing multiple images at once.
