The learning process continues. The restoration of some 8mm film captures has been very rewarding with great results. However, I notice that I see jitter on both sides of the preview frame. The video inside the frame is fine just the edges.
Also, is it possible to adjust contrast of the video.
Hi Bob! No, you will not be able to alter contrast or any other basic video adjustment. For this, I like Resolve and Adobe Premiere
I am not quite sure what you are describing, could you share a screen recording?
Oftentimes it is easiest to share a screen recording for issues like this to quickly show me exactly what is happening. I use Loom for screen recordings since this is a free and easy to use app.
Ida, I uploaded the original unprocessed clip to your Dropbox link. My process flow was
Upscale to HD
Filters:
Stabilization-Reduce Jitter Motion
Motion Deblur
Output Settings:
H264 High
MP4
This is occurring due to the pillar boxing that is being added when upscaling and how this is interacting with the stabilization model. To avoid this, you can use auto-crop instead of full frame., however, you will lose some of the image.
Thank you so much for this information. I am so impressed at the incredible job the software has done with my B&W films from the 1950’s. I will make change in the process flow you suggested.
