Preview Button Erroneously Locked When No Transform Settings Are Changed
    If I generate a preview, for example “Preview (5 frames)”, the Preview button ghosts and becomes unavailable-- I understand the presumed logic here: “Why re-render when nothing has changed?”
    HOWEVER, I was pleased with the 5-frame result, so I just want to render a longer preview with the exact same settings. This, I can not do, because I can’t use the Preview button.
Random thought: If I try to re-render something exactly as I have rendered previously, treat it like an INSTANT result, and if I try to re-render the exact same thing, just switch me to the correct existing result, and take advantaged of the already-rendered frames if I generate a longer preview from it.
(I did do a search)
Exactly. I have encountered this over and over and it should be corrected. There is no need to lock the button if I want to view a longer preview.
If you move the play head the preview button will unlock and you can change the duration.
