Presets I create do not store/save the Preview and Export Settings I determined.
Encoder / Encoder Profile and Container reset each time despite having selected to update the preset.
Can this be a future option that these fields are also locked to the preferred setup in a newly created preset. The other options in Preview and Export Settings are default so I have not seen/tested if these jump back also over a preferred choice.
Nevermind found the checkbox to include Export Settings.
