Apologies if this is a re-post but I noticed since my last update, my presets are not how I originally saved them. Some of the models have changed to a different ones, and I know because I named them specifically to know which models they were using.
Also it might be helpful if there’s an easy way to edit a preset instead of always creating a new one if you want to make a small change.
Yes different models show. So for example, I had a preset that I named Gaia60, because I set it to 60fps with the Gaia model, but with the most updated version, when I pull my preset its the proteus model that is there by default. There are little changes like this for all my presets.
Sure here’s a screenshots of my presets and my logs attached.
I notice it does say modified after I select my preset, but it shows that way whether I modified it or not. ANd the model is now showing Proteus instead of Gaia as it used to be.
