Any progress on this issue? It is really annoying and it is eroding my confidence in the settings I have worked for hours to refine. I can’t see how to edit or save an existing preset and that is totally unlike other software I use. I don’t like VAI messing about with MY presets!
This should be fixed with the release of v3.3.6 which is currently in Beta
