Preserve Text not working
Preserve text does not work correctly. Text look approximately the same with and without it. Both AI model Low Resolution and Noisy are unsatisfactory.
Steps to reproduce issue:
Always when used.
Topaz Labs | Support Page
I reverted to 2.3.2 and it works better for me.
Same here. Preserve text is simply not working as it should in 2.4.2.
