Poor quality /blurry preview
Hi, Photo AI loads RAW from Olympus OM-1 (first generation), but the preview when working in the editor is poor quality at 100% scale - as if in low resolution. It is not possible to estimate the degree of sharpening, it works very poorly. After exporting RAW to DNG, when I open the DNG in Lightroom, the photo quality is excellent. I am adding screenshots (100% scale cutout). I’ve had this problem the whole time I’ve been using Photo AI. In the case when I edit TIF and not RAW, everything is ok. I have the same problem with RAW files from the old Nikon D90.
Steps to reproduce issue:
  1. Open Lightroom
  2. Select photo in Libray, File - Plugin Extras - Proces with Topaz Photo AI
  3. Photo preview in Topaz is poor quality
  4. Exporto to DNG, open DNG in Lightroom - image quality is ok.
Topaz Photo AI [v3.2.1] on [Mac]
MacBook Air.spx (6.8 MB)
  1. The original image file.
  2. The processed image.
Dropbox File Request
Uploaded. It doesn’t matter what photo adjustments are chosen, whether it’s just denoise or sharpening, or both. The preview is always in poor quality.
