Plugin issue with Capture One Pro
Steps to reproduce issue:
  1. Step 1: export RAF file from C1 23.3 to Photo AI 2.2 using Plugin
  2. Step 2: make adjustments and save for C1
  3. Step 3: check WB in C1 and you will see that it is completely off - not
    Bildschirmfoto 2023-12-17 um 14.24.25
    so with the standalone
Posted also with General Discussion - sorry!
I have the same problem with the latest version of Topaz Photo AI
