I shoot dark for affect, when I use plug-in Photo AI I can’t see the detail where the LR Photo Ai keeps the settings from LR so I can see what I’m doing
Hi @tom.sergio, if you are using the File > Plug-In Extras workflow this is normal behavior, any Lightroom changes cannot be carried over to the new DNG that is created by this workflow – you will need to copy and paste your Lightroom settings to the new DNG after processing completes.
The Photo > Edit In > Topaz Photo AI workflow will convert your image to a TIFF, which will ‘bake in’ your edits.
