Please provide toggle for Subject Detection
I often have photos that do not have a clear subject (eg. Northern Lights photos). A toggle for Subject detection (similar to those for the other functions) would 1) eliminate the wait for the program to try to find a subject and 2) eliminate the need to go into the sub-menu to select “None” and then “Done” when the program incorrectly thinks it found a subject. Furthermore, it would streamline the process when sharpening is desired across the whole image and not just the subject.
Turn it off in the AutoPilot Settings …
Turn it on when you need it by: Select
Select what type of Subject then, if needed, refine using the brush:
