Depending on the number entered, I must wait up to 30 seconds for the playhead to reach the requested frame. That is very annoying, considering that I use that feature two times (to set the IN and the OUT) for every single clip I process with VideoAI.
There can be some delay in selecting frames depending on what other apps you have running in the background and the size of the video input, resolution and the AI models being applied.
Try clearing the Plist for Video AI and restarting the app to see if that helps.
Dear @kyle.topazlabs, before replying to other users’ questions, could you try understanding the issue and possibly reproducing it on your machine? Instead of making me do a further investigation (actually involving me in a process that is supposed to be carried out by a Topaz employee), why don’t you confirm that Video AI executes the mentioned task with no delays on your machine?
As I stated there can be a delay at times depending on the clip or clips you have loaded in the app and what else is running on your system at the time. In that test I did have other apps running in the background but this is a short clip that did not have any effects applied to it yet.
