Why can’t Starlight Precise just leave my pixel aspect ratios alone? All I want is a 2x upscale in both dimensions. 720 x 480 should become 1440 x 960. Instead, I’m getting 1280 x 960 or 1310 x 960, depending on whether I choose square pixel or original pixel. This is a complete nightmare to edit back into a project, I am having to manually change the height and width scaling on a shot by shot basis. Seriously, just multiply by 2 in both dimensions! Is it really that hard? This is costing me hours and hours of labor.
This is version 1.70 of Topaz Video and Starlight Precise 2.6, on a Mac Mini.
The devs are working on some issues that have been reported about aspect ratios being altered when being processed. Can you send the logs from your processing attempts for their review?
We will run some tests on our end as well to replicate the situation as well.
I did notice that some files are being seen as 640x480 when being read by the app, this is something the team has been working on with how the app reads the metadata for when a file has multiple PAR and DAR sizes linked.
In my experience, the metadata in video files of analog captures of SD media is very often wrong, it is quite likely wrong in the files that I upscaled. I would like a setting that just completely ignores the metadata and aspect ratio and just provides a true 2x (or 3x or 4x) upscale of the pixel count in both x and y dimensions. When doing restoration work, I sometimes need to layer multiple upscales together with the original file in different layers in Davinci Resolve. When the aspect ratio shifts it makes lining up all these layers quite time-consuming.
In such cases, I remux with MKVToolNix and set the DAR manuall or remove size settings and DAR, and then Topaz should use the native pixels, without giving you the “square pixel” option.
By the way, if the source is 720×480, and if the content was made for 4:3 play, and the video file is also flagged with correct 4:3 DAR, Topaz displays me that the source was turned into 640×480 when using the “Square Pixel” function.
I don’t think lowering to 640×480 is optimal here. But I’m not sure what Topat really does internal. However, it would good when Topaz converts 720×480 to 720×540 → gives you 1440x1080 when you do 2x upscale.
