Photoshop Elements 2021 crashes using Photo AI Remove Noise
Photoshop Elements 2021. Using Topaz Photo AI Remove Noise My graphics card is a Radeon RX570 series Using Windows 10
But works fine in Topaz Photo AI on its own. So it seems the problems with Photoshop Elements.
Please open Topaz Photo AI, go to the menu bar on the top and click the Help > Open Log Folder menu option. Attach the logs to your reply so I can check the contents.
Hi Lingyu
Thank you for your reply its most appreciated.
But since I asked the question the new updates to the software have now got the Photo AI working fine again thank goodness. But if anything changes, I’ll let you know.
Again thanks
regards Bob
