Using Photo AI in a PS action causes a bug in the Authentication module to pop up and require authentication EACH TIME the Action is run and then stops the PS Action and requires manually hitting “OK” and then manually continuing the Action until until done. Doing it manually, i.e., not embedded in an Action, there is no authentication demand.
ALSO, sometimes unpredictably it goes into “QUEUED” Mode permanently with nothing “queued” and you have to quitPhoto AI and try again…
Steps to reproduce issue:
- Create an action that accesses PhotoAI
- Run the action.
- Watch PhotoAI stop the action
Topaz Photo AI [v2.1.2] on Mac OS" 13.4.1 (22F82), M2MAx chip, 64 GB RAM…PS2024
