PhotoAI 2.4.0 Crashes, especially when using Remove selection tool
PhotoAI 2.4.0 has been crashing, especially when using the Remove selection tool. I am running LR V13.2 opening PhotoAI on Raw file under plug-in Extras.
It first happened after I successfully selected and removed one object, and when I tried to select another it crashed on several attempts. After that it crashed on the first attempt to select anything.
I have attached files with my system info and Topaz log files.
System Info 2024-03-12.txt (13.9 KB)
2024-03-12-21-19-27.tzlog (224.4 KB)
2024-03-12-21-20-47.tzlog (217.2 KB)
2024-03-12-21-22-20.tzlog (623.1 KB)
2024-03-12-21-47-54.tzlog (150.0 KB)
2024-03-12-21-49-4.tzlog (104.4 KB)
The couple of times I was able to select and process the remove tool it seemed to work well.
Thanks,
Mike
I failed to mention that it failed using the Object selection tool. In this case on a dark bird against light colored water. There was an overlap with the primary objects dark beak which could have been a problem, but I would not expect a crash. I attached a screen capture of the image section in question.
Topaz Labs | Support Page
