Photo AI with TIFF Desaturates Color in Adjust Lighting
Steps to reproduce issue:
  1. Step 1
    Export Photo as TIF No Adjustments.
  2. Step 2
    Adjust Lighting To 25+ Than done
  3. Step 3
    Save Photo .
    IMG_3256.CR2 (18.1 MB)
Mac
Version 420
Archive 2.zip (352.2 KB)
  1. The original image file.
  2. The processed image.
Dropbox File Request
Adjust Lighting to gradual Several times 25 to 100.
3256 PhotoAI will leave Dark w/o Lighting.
In Balance Color make it so some one can enter a number like 8213 and 5544 .
Remove alone a Border needs a PAD on outside of Entire Photo and Remove Can work in Portions of it.The Selection can be less then the Think of In PHotoShop just the Work area being Larger but Photo size is same.
Original
Several Processed
Original w/o Enhancements to TIFF for PhotoAI To Adjust Denoise Balance Color,ect.
And Screen Shot
I have a filterforge it lets me design specific filters in photoshop.
Patterns and more.like a solid color background Lab ,HSL,hsb.
