Photo AI v.1.5.1 -- Major Hurdles to My Regular Workflow
New User of Topaz Photo AI, using v. 1.5.1; Long time user of Gigapixel, DeNoise, and Sharpen.
I see and appreciate the effort you guys have poured into this ambitious integration of your photo technologies. I’m writing to express two issues with Photo AI that could prevent me from maintaining my license after the 30 day trial period vs keeping my money in and thus supporting its evolution over the next year.
My concerns:
First, your Upscale mode is critically hamstrung vs. Gigapixel. No way to save a tiff in 16 bit format? For me this is a severe limitation. Not as critical, but annoying: no way to select a Color Profile.
Second, Photo AI’s processing time compared to, for example, DxO’s PureRaw, which handles a well balanced and useful combination of noise reduction and lens profile based sharpening in a quarter to an eighth of the time, is a real barrier to using Photo AI as a regular component of my workflow. Indeed Photo AI provides much more nuanced results, but when both noise reduction and sharpening are needed, the multiple passes required when saving the image produce a really steep time/performance curve.
Thank you for considering my comments,
Brad Beukema
2019 Intel MacBookPro, AMD Radeon Pro 5500M 8 GB
In the current beta 1.5.2.0.b saving to tif 16 bit is avaiable again!
What is the input file when you tried to save it out as 16-bit TIF. We do allow for saving in 16-bit TIF, but if there is a specific file type that is not allowing it then I can check the behavior.
Dropbox File Request
Topaz Photo AI processing is expected to take longer than DxO. There are more processes in Topaz Photo AI to improve the image. It will also allow control over the processing, which other applications do not have.
The graphics card on this computer is fairly low performance. It has decent VRAM but the processing is not very good. Do you have another computer you could try using Topaz Photo AI on?
Thank you, Lingyu,
I looked into the saving of 16-bit TIFFs in Photo AI and found that when selecting to save the TIFF with LZW compression, only 8-bit depth is allowed. With no compression or with ZIPed compression, 16-bit depth TIFF is allowed. Curious, why not with LZW compression, a curious limitation.
Best.
I just spoke to my team about this. Seems that LZW 16-bit compression is worse than using no compression. Here’s a comparison from this article discussing compression results on TIF:
Thank you. Your responsiveness is informative and appreciated.
Lingyu, regarding Photo AI performance, you asked me if I had an alternative to my 2019 MacBook Pro.
I’m looking at a new MacBook Pro, M2 Max. The “affordable” version would spec out at:
12-Core CPU
30-Core GPU
32GB Unified Memory
Would this seem sufficient for handling Photo AI processing? Thanks.
Yes that hardware would be far above the minimum requirements. The M2 chip has great processing and is recommended for Topaz Photo AI.
Let me know if you have further questions about it.
