When using Topaz Photo AI to remove noise I came across some structures that were introduced by that process (or at least I cannot make them appear before using denoising). The screenshot of the preview already shows it in the upper part of the right panel with the settings applied for preview.
It is hard to make out but once you see it it can’t be unseen. Look for slightly lighter horizontal lines in the sky. They are easier to spot if you take the screenshot and put a reversed S-curve on it:
It’s horizontal and vertical lines, the horizontal ones being a bit lighter, the vertical a bit darker than the surrounding areas. These structures only appear in the right side of the preview (i.e. in the one with the preview applied). It’s not a preview issue, as I discovered it on the further processing of the image.
Steps to reproduce issue:
Step 1
Load image from CameraRAW to Photoshop. Invoke Photo AI.
Step 2
Select ‘Removing noise’
Step 3
Look for the structure in preview window.
Topaz Photo AI [v1.4.3] on [2019 iMac 27" i9, Radeon Pro 580X]
Please send me the original image so I can try to reproduce this.
You can securely submit your image(s) to my Dropbox using the link below. Please be sure to send me a note to let me know you sent something. Dropbox File Request
Thanks Lingyu!
Yes, it is very faint and I’m not surprised that it hasn’t been recognised earlier. It’s just that in further processing of the images (i.e. spreading the tones in skies and similar things or applying pseudo HDR or increasing micro contrast) these structures become visible without looking for them. These post processing procedures are also the reason I need the de-noising in the first place.
I’m happy that it isn’t something related to the camera as I’m confident you can eliminate this in future releases.
Keep up the good work!
