I tweaked the subject for the Denoise enhancement, but when I next selected the Sharpen enhancement, Photo AI 3.1.0 (Windows 11) didn’t remember my subject tweaks so I had to do them again.
Steps to reproduce issue:
Select Denoise from suggested enhancements list.
Modify the Subject using the “Regular” painting method.
Execute Denoise.
Select Sharpen from suggested enhancements list.
Check the Subject and find that my Subject enhancements weren’t remembered from Denoise.
This is expected behavior for the application and its processing however I will go ahead and add this ticket to our Ideas section on the Community Forums!
Make sure that you do not forget to vote for your idea
It may be an expected behavior but it doesn’t seem very rational to me: it can take a long time to define a subject exactly and having to do it again for each applied function seems absurd to me. Perhaps honestly rather than expected behavior it would be appropriate to say that we hadn’t thought about it
