When using autopilot on NEF files that are set to use “Strong” noise reduction, it does not use the GPU and takes a long time, if you override and use the “Normal” setting it uses the GPU and is much faster. Working on jpeg files for noise always uses the GPU.
The sharpening stage uses the GPU fine on all file types.
Steps to reproduce issue:
Choose noisy NEF file
Allow Autopilot to initiate sequence
Use MSI Afterburner to watch GPU usage
Any ideas
Topaz Photo AI v1.3.6 on Windows using NVIDIA GEForce GTX 1660 Ti 2023-05-30-09-42-5.tzlog (547.9 KB)
“We have temporarily pulled back the GPU models for denoise in particular because they were causing stability issues. So at the moment denoise will be slower than it was previously on Windows machines. We are working on adding them back as well as updating the denoise models in general, but those models are still in beta.” - it has been fixed in the BETA denoise model for non-RAW, but not in the RAW versions yet.
