I use Photo AI as a plug in for Elements 2022. It worked just fine until about a week or so ago. Now, Autopilot will not remove noise automatically. After I activate the plug-in, it scans the photo, then it starts its magic. The Denoise function turns on briefly, then turns off, no matter how noisy the photo is. I need to manually change the position of the slider before it will remove noise.
How can I get autopilot to return to full automatic?
Tim, I am ready to do as you suggest, but please excuse me if this is a dumb question. Should I uninstall the program first, or reinstall on top of it?
Thank you very much. I will wait for your response.
