Photo AI autopilot is no longer automatically removing noise
All of a sudden, PhotoAI has stopped removing noise on autopilot. It is necessary to delete the sharpening, then add the denoise enhancement, then add the sharpen enhancement. What happened?
Can you try going to Preferences > Autopilot > Remove Noise and adjusting your default settings to suite the images you are working with in Topaz Photo AI?
Thanks, John. The problem seems to have cured itself, but I’ll keep this in mind if it happens again.
