Photo AI aupport for OMSystem OM-1 Mk II RAW files
Is there any schedule for Photo AI aupport for OMSystem OM-1 Mk II RAW files?
Our developers have been working on this camera profile.
Could you send us 1-2 RAW files from the OM-1 Mark II so we can check if it’s working in Topaz Photo AI?
For these Mark II updates, the files are sometimes unchanged from the Mark I, so it may work without adding support.
You can securely submit your files(s) to my Dropbox using the link below. Please be sure to send me a note to let me know you sent something.
Dropbox File Request
Hello,
I sent you one OM-1 Mk II file for your examination.
Thanks for sending those in :slight_smile:
I’ve made a note to our developers to create a solution for this and they’re currently investigating it.
We appreciate your patience and understanding while we get this fixed for you!
The OM-1 MkII issue has been fixed in the most recent version release, v2.4.1
Topaz Labs | Support Page
Seems to work. Thank you
-Pekka
