Photo AI and Sequoia - PC crashes
Over a 48 hour period my Mac Book crashed many times. Uninstalling PhotoAI seems to have solved the problem - I have received the offer to update, but this is not a good idea until I know that the upgrade runs smoothly with Sequoia. Am I the only one having this problem?
Steps to reproduce issue:
  1. Step 1
  2. Step 2
  3. Step 3
I’d like to get some more information to help troubleshoot the problem you are having.
Could you send us your computer’s full system profile?
Also if you can, please try to recreate this crash in Topaz Photo AI, then go to Help > Open Log Folder, please send me all of the files within that folder. You should be able to attach them directly as a response to this thread.
If you would prefer you can securely submit your files(s) to my Dropbox using the link below. Make sure to send me a note to let me know you sent something. :slight_smile:
Dropbox File Request
