Photo AI v3 is uselessly slow, will get stuck when opening resulting in a force quit. MacBook 16.1 Somona 14.4.1, 2.3 Ghz I9, AMD Radeon Pro 5599M 4GB, 32GB RAM. Should I uninstall and reinstall?
