I am using Window 11 on a desktop. Since it’s release, Topaz Photo AI has always shown up as an option under “Edit With”. Installed both new versions as noted above in title and it does not show up anymore. Have tried reinstalling both with no luck.
You don’t add the required information for reporting a “bug”, not even OS. But …
This is an issue with C1 explained on their forums and manual … right-click on an image on the explorer/finder, select open with Photo AI and after that it will be available. Then go to plugins in settings and make sure Photo AI is selected.
Although it says PS it is a template for external editors.
